Jeff Hiller
        COMSOL Employee
                                8 years ago
                                06.12.2017, 08:56 GMT-5
                        Updated:
                                8 years ago
                                06.12.2017, 08:58 GMT-5
                                                    Hello Osman,
If you do not want to solve any equation in a particular part of your geometry (here, your cylinder), you should simply remove it from the geometry (Geometry>Boolean Operations>Difference).
If you need to solve some equations but not others in a part of your geometry, you need to be a bit more subtle and assign different domains to the different physics interfaces. From your post, this does not appear to be your case, but I am mentioning this for others who may read this thread some day.
    Jeff Hiller
                            Hello Osman,
                                8 years ago
                                06.12.2017, 10:29 GMT-5
                                                    Thank you very much for your response Jeff!
Actually I tried  the "Difference" and I had the same problem. However I have just noticed that, "Keep input objects" were thicked under the Difference. I am sorry.
Thanks a lot again,
Osman
Thanks a lot again,
Osman
