Confused about few materials inside COMSOL
Dear Sir, I am using following material for simulation of my desired geometry. Soil, Concrete, Steel, Cast Iron, Polymers, Rubber When I go inside the material library I get confuse which type of sand, steel, polymer or rubber i should assign. Since I know basic property of my material like Young's Modulus, Poission ratio, Density but don't know how to select appropriate material from material library. Mostly Soil portion make me more confuse. As I want to use sand, silt and clay but regarding sand I find few material but for silt and clay i did not find any material. Please help me in this regard.
Thank you
4 Replies Last Post 14.11.2017, 06:20 GMT-5
Posted: 7 years ago 02.11.2017, 23:01 GMT-4
Right-click Materials, select Blank Material. Add the properties of interest from the list under Basic Materials. Finish up by giving the material an informative name. Repeat for your other materials.
D.W. Greve DWGreve Consulting
Right-click Materials, select Blank Material. Add the properties of interest from the list under Basic Materials. Finish up by giving the material an informative name. Repeat for your other materials. D.W. Greve DWGreve Consulting
Posted: 7 years ago 03.11.2017, 09:44 GMT-4
Updated: 7 years ago 14.11.2017, 08:15 GMT-5
Muhammad,
It sounds like you work with geomechanical applications. Please make sure that your license includes the optional Geomechanics Module, as that is the one which includes material laws suitable for that field (Cam-Clay for clays, etc, see https://www.comsol.com/geomechanics-module ), and in particular plasticity with non-associative flow rule. See e.g. https://www.comsol.com/blogs/yield-surfaces-plastic-flow-rules-geomechanics/
If all you want to do is specify a linear elastic small deformation Hooke's law behavior defined entirely by Poisson ratio and Young's Modulus (plus the density in the dynamic case), then no optional product is necessary and you can add those properties as D.W. describes above.
Jeff Hiller
Muhammad, It sounds like you work with geomechanical applications. Please make sure that your license includes the optional Geomechanics Module, as that is the one which includes material laws suitable for that field (Cam-Clay for clays, etc, see https://www.comsol.com/geomechanics-module ), and in particular plasticity with non-associative flow rule. See e.g. https://www.comsol.com/blogs/yield-surfaces-plastic-flow-rules-geomechanics/ If all you want to do is specify a linear elastic small deformation Hooke's law behavior defined entirely by Poisson ratio and Young's Modulus (plus the density in the dynamic case), then no optional product is necessary and you can add those properties as D.W. describes above. Best, Jeff
Posted: 7 years ago 14.11.2017, 06:19 GMT-5
Thank you very much.
>Right-click Materials, select Blank Material. Add the properties of interest from the list under Basic Materials. Finish up by giving the material an informative name. Repeat for your other materials. > >D.W. Greve >DWGreve Consulting Thank you very much.
Posted: 7 years ago 14.11.2017, 06:20 GMT-5
Muhammad,
It sounds like you works with geomechanical applications. Please make sure that your license includes the optional Geomechanics Module, as that is the one which includes material laws suitable for that field (Cam-Clay for clays, etc, see https://www.comsol.com/geomechanics-module ), and in particular plasticity with non-associative flow rule. See e.g. https://www.comsol.com/blogs/yield-surfaces-plastic-flow-rules-geomechanics/
Thank you for your help
>Muhammad, > >It sounds like you works with geomechanical applications. Please make sure that your license includes the optional Geomechanics Module, as that is the one which includes material laws suitable for that field (Cam-Clay for clays, etc, see https://www.comsol.com/geomechanics-module ), and in particular plasticity with non-associative flow rule. See e.g. https://www.comsol.com/blogs/yield-surfaces-plastic-flow-rules-geomechanics/ > >If all you want to do is specify a linear elastic small deformation Hooke's law behavior defined entirely by Poisson ratio and Young's Modulus (plus the density in the dynamic case), then no optional product is necessary and you can add those properties as D.W. describes above. > >Best, > >Jeff Thank you for your help
