Far-field calculations bug in COMSOL version 4.1
Posted 22.03.2011, 05:28 GMT-4 RF & Microwave Engineering Version 4.1 0 Replies
1) Going few lambda away from the scatterer and integrating scattered field usually gives good results, but the number of mesh points is huge.
2) Introducing very thin vacuum layer around the scatterer and integrating far-field on the surface in the middle of this vacuum layer works well, but the mesh requirements are again huge.
3) Let's say you need solution for lambda0=800nm in water n_w=1.33. You can run the simulation for lambda0/1.33 with n_w=1 and change the permittivity of gold from e_re(f)-i*e_im(f) to 1/(1.33^2)*(e_re(f/1.33)-i*e_im(f/1.33)). This results in equivalent problem and built-in Stratton-Chu far-field works well.
Might be a bug in other versions of COMSOL too. I would check it if I were you.
Hope this helps.
Martin
Hello Martin Ploschner
