21.03.2011, 10:28 GMT-4
try to define 2 periodic conditions with only one source + destination pair per item i believe that will help
21.03.2011, 10:48 GMT-4
Hi Ivar,
Thanks for the reply. I have defined 2 periodic conditions with only one source + destination pair per item. But this time it is not even converging. Earlier it was properly converging and giving negative temp.
The error message is
Repeated error test failures. May have reached a singularity.
Time : 0
What is the problem. Can you pl,. check the model?
Hi Ivar,
Time : 0
21.03.2011, 11:56 GMT-4
I did a quick check, and I believe I only changed that, but I'm running the latest patch, that might make a difference ;)
21.03.2011, 12:23 GMT-4
Did you mean version influence on results?
check the attached latest model with the periodic BCs defined as suggested.
The same error message is seen. There are no time varying sources and I have even changed the time stepping also. Not successful.
I have even run the modified model in V4.1 also and it says property solnum out of range. One more difference I have seen in 4.1. In 4.0 all the faces are defined as thermally insulated but if we open the same model in 4.1 then only top and bottom faces are considered as thermally insulated. Others faces it simply does not allow to define as thermally insulated as they are defined as periodic. But in 4.0 it allows thermal insulation for all other faces as well.
Your help is appreciated,
22.03.2011, 02:54 GMT-4
What I clearly understood from the COMSOL conferences about two years ago now, was that V4.0 was a preliminary release to allow you to learn the new approach and to get feedback, so I used it in this way too. Since the 4.1 is here I have fully dropped 4.0, and I do not even try to import 4.0, I rebuild them in the latest version. With the last version I have no major issues, so I'm happy like that.
Now back to your issue. The solnum error appears for me if you do not clear correctly the solution, I mostly DELETE the solution of a old version when I try to load them.
If I run your model as is I get the same errors and "0" as result, if I delete the solution and solve it, it stops at 19.98 sec and hangs there. If I restart and stop it after 3-4 seconds it show clearly it has started to solve correctly, so there must be something else too in there ;
