CFD & Heat transfer analysis of disc brake. Multiphysics Simulaton, Conjugate heat transfer with turbulent flow
Hey Everyone,
I am trying to simulate CFD of disc brake to understand the airflow and how it affects the cooling of the disc brake. I am using Conjugate heat transfer module with turbulent flow. I made a basic geometry of disc and hub.
I am attaching the model below.
Thanks in advance for any suggestions or help.
Abdul Haq
2 Replies Last Post 05.09.2017, 12:48 GMT-4
Posted: 7 years ago 05.09.2017, 06:19 GMT-4
Just from a quick glance:
Can you argue on why you assume the flow to be turbulent?
Maybe consider switching to a low Re turbulence model, eg. SST, in case of flow separation over the curvature. Also, it does not look like there is a boundary layer mesh on the disk+shaft; I would really suggest building one.
I also think you might have put the wrong sign on the inlet velocity.
Best regards
Philip
Just from a quick glance: Can you argue on why you assume the flow to be turbulent? Maybe consider switching to a low Re turbulence model, eg. SST, in case of flow separation over the curvature. Also, it does not look like there is a boundary layer mesh on the disk+shaft; I would really suggest building one. I also think you might have put the wrong sign on the inlet velocity. Best regards Philip
Posted: 7 years ago 05.09.2017, 12:48 GMT-4
I was considering the flow to be turbulent due to the air flow. I mean, the car average speed is 30 mph, thus I was considering that.
I would do as you said.
thanks a lot.
I was considering the flow to be turbulent due to the air flow. I mean, the car average speed is 30 mph, thus I was considering that. I would do as you said. thanks a lot.
