How to simulate contact with transient analysis?
I am simulating slab with surface crack in heat transfer & solid mechanics domain.I have given contact pair at the crack faces.I have to do transient analysis.Some error is coming during simulation.It tells some initial value is missing. I s it possible to simulate contact physics with transient analysis?/
Pls help..
Regards!!
Deepak
1 Reply Last Post 14.03.2011, 09:24 GMT-4
Posted: 1 decade ago 14.03.2011, 09:24 GMT-4
I belive so, but the best is always to check your initial values with a load initial values (in v4 right lick on the Dependent Variables node and "Compute to selected"
Hi I belive so, but the best is always to check your initial values with a load initial values (in v4 right lick on the Dependent Variables node and "Compute to selected" -- Good luck Ivar
