time-varying current in model
I am trying to send a time-varying current through a component i built in COMSOL. Does anyone know how to do this? I cannot use the time-harmonics case because the current should decay with time.
Dan
1 Reply Last Post 07.11.2009, 10:44 GMT-5
Posted: 2 decades ago 07.11.2009, 10:44 GMT-5
If you are doing time depending solving, the variable "t" is defined, so isn't this "just" defining your specific variable(s) as function of "t".
An example of a step
voltage = V0*(t<1)+V1*flc2hs(t-1,0.1)
Or have I missed a point in your question ?
Hi If you are doing time depending solving, the variable "t" is defined, so isn't this "just" defining your specific variable(s) as function of "t". An example of a step voltage = V0*(t
