Changing the physics applied after time frame
Hello all,
I am running COMSOL 4.2, with the AC/DC and the Heat transfer modules. I have built a model that simulates the temperature change caused by joule heating in an electrochemical cell. However, the simulation I need to run now involves an additional heat source that does not activate until 1 hour into the simulation. Is this a process I can program into the simulation?
Thank You
1 Reply Last Post 25.07.2017, 02:22 GMT-4
Posted: 8 years ago 25.07.2017, 02:22 GMT-4
Say your heat source is Q then you can enter Q*(t>1[h]).
This simple way has a jump discontinuity and you may want to replace it
with a smoothed step function.
Regards
Jens
Say your heat source is Q then you can enter Q*(t>1[h]). This simple way has a jump discontinuity and you may want to replace it with a smoothed step function. Regards Jens
