How to draw a circle on a cylinder surface
Dear all,
I want to draw a circle on a cylinder surface, but the work plane only provide a planar surface, which cannot be coincided with curved surface. Do you have any available approaches to achieve that?
Thank you for your help.
2 Replies Last Post 08.07.2017, 03:19 GMT-4
Posted: 8 years ago 07.07.2017, 22:58 GMT-4
Create another cylinder that intersects with your cylinder, and execute an intersection (Boolean) operation between them. Delete any leftover geometry elements that you don't want.
Posted: 8 years ago 08.07.2017, 03:19 GMT-4
You have to define what a circle on the cylinder surface is for you. A circle is inherently a flat (2D) curve that doesn't exist on a curved surface.
Robert's approach projects a circle on a cylinder surface but this curve does not fulfill a circle's implicit definition in 3D:
If you need something like this you may try to find a suitable parameterization. However , in turn the projection of such a curve on a 2D plane will no longer look like a circle.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
You have to define what a circle on the cylinder surface is for you. A circle is inherently a flat (2D) curve that doesn't exist on a curved surface. Robert's approach projects a circle on a cylinder surface but this curve does not fulfill a circle's implicit definition in 3D: [math] (x - x_0)^2 + (y - y_0)^2 +(z - z_0)^2 = r^2[/math] If you need something like this you may try to find a suitable parameterization. However , in turn the projection of such a curve on a 2D plane will no longer look like a circle. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
