export plot data to txt file
hi
i want to export the plot data from a slice-plot (dimensions: 1mx1m) into a txt-file.
as result i get a txt-file which has a size of ~8MB, but unfortunatly it does not contain the data from the whole plot. i think that maybe there is to much data.
so i know that i can reduce the size of data with a coarser mesh.
but is there an other way to limit the data size. is it posible to assign an area inside the slice plot so that i can only export the plot data of this area?
thanks in advance for your efforts
Simon
3 Replies Last Post 03.03.2011, 16:10 GMT-5
Posted: 1 decade ago 03.03.2011, 14:40 GMT-5
via matlab you can aleways re-interpolate over a coarser grid, not sure how to in the COMSOL v4 GUI. But if you do not need the full area cut your domain with a urface and define just the region of interest, if its an "interiour" boundary at most you add a little to your matrices, and a few nodes on the interiour boundary but this seldom gives convergion issues, on the otehr side its easy to pick a boundary and then use it to integrate or average our variables.
You also have the extrusion coupling variables that could be used
Hi via matlab you can aleways re-interpolate over a coarser grid, not sure how to in the COMSOL v4 GUI. But if you do not need the full area cut your domain with a urface and define just the region of interest, if its an "interiour" boundary at most you add a little to your matrices, and a few nodes on the interiour boundary but this seldom gives convergion issues, on the otehr side its easy to pick a boundary and then use it to integrate or average our variables. You also have the extrusion coupling variables that could be used -- Good luck Ivar
Posted: 1 decade ago 03.03.2011, 15:16 GMT-5
hi
Simon
maybe it has something to do with Java memory size allocation in comsol.ini. Maybe you can increase them and see if it works.
Danial
Comsol 4.1
Ubuntu 10.04.1
[QUOTE] hi i want to export the plot data from a slice-plot (dimensions: 1mx1m) into a txt-file. as result i get a txt-file which has a size of ~8MB, but unfortunatly it does not contain the data from the whole plot. i think that maybe there is to much data. so i know that i can reduce the size of data with a coarser mesh. but is there an other way to limit the data size. is it posible to assign an area inside the slice plot so that i can only export the plot data of this area? thanks in advance for your efforts Simon [/QUOTE] maybe it has something to do with Java memory size allocation in comsol.ini. Maybe you can increase them and see if it works. Danial -- Comsol 4.1 Ubuntu 10.04.1
Posted: 1 decade ago 03.03.2011, 16:10 GMT-5
check www.comsol.com/support/knowledgebase/1092/
for the java ini
Hi check http://www.comsol.com/support/knowledgebase/1092/ for the java ini -- Good luck Ivar
