How can I optimize the Time-step in Time-dependent analysis
NDN UNIST/Mechanical Engineering
Hi all
I am doing the Time dependent study for Particle Tracing for Fluid flow. But actually I am clear the value of Time-step.
If we consider two case of Time range as:
Case 1: range(0,1,10)
Case 2: range(0,0.01,10)
Both begin with 0s and end with 10s but only different by Time-step.
So, which value of time-step is better ? is more accurate ? And the result of simulation is same or different ?
thanks so much for your reading my topic
2 Replies Last Post 22.06.2017, 11:42 GMT-4
Posted: 8 years ago 22.06.2017, 11:40 GMT-4
There have been several discussions on this topic in the Discussion Forum. You will find them with a search.
One for instance that discusses the relation to tolerances and accuracy is this one: www.comsol.com/community/forums/general/thread/50111
See also this one where it is explained why the final time impacts the entire solution:
www.comsol.com/community/forums/general/thread/108101
There have been several discussions on this topic in the Discussion Forum. You will find them with a search. One for instance that discusses the relation to tolerances and accuracy is this one: https://www.comsol.com/community/forums/general/thread/50111 See also this one where it is explained why the final time impacts the entire solution: https://www.comsol.com/community/forums/general/thread/108101 Best, Jeff
Posted: 8 years ago 22.06.2017, 11:42 GMT-4
Thanks so much, Dr.Jeff Hiller
