Finding coordinates and dimensions of a point in COMSOL model
I have imported a CAD model into COMSOL. But I am not able to find out the coordinates and size of a small pipe in the model. I want to know the dimensions of the pipe and its position in the model exactly so that I can make some desired changes to the model. Please help in finding those details.
4 Replies Last Post 13.07.2017, 12:00 GMT-4
Posted: 8 years ago 20.06.2017, 12:33 GMT-4
Hello Saurhab,
Use the Measure tool found on the Geometry ribbon for that. When a point is selected it will return its coordinates. When a surface is selected, it will return its surface area.
Hello Saurhab, Use the Measure tool found on the Geometry ribbon for that. When a point is selected it will return its coordinates. When a surface is selected, it will return its surface area. Best, Jeff
Posted: 8 years ago 02.07.2017, 20:07 GMT-4
Thanks Jeff,
It's a very important tool in COMSOL modeling.
Can you explain how to incorporate a new equation in COMSOL model for reaction engineering which is not inbuilt in COMSOL?
Saurabh
Thanks Jeff, It's a very important tool in COMSOL modeling. Can you explain how to incorporate a new equation in COMSOL model for reaction engineering which is not inbuilt in COMSOL? Saurabh
Posted: 8 years ago 13.07.2017, 11:43 GMT-4
Hi Saurabh,
I suggest you start a separate thread, as this new question is unrelated to the current thread. You will be more likely to get answers.
Hi Saurabh, I suggest you start a separate thread, as this new question is unrelated to the current thread. You will be more likely to get answers. Best, Jeff
Posted: 8 years ago 13.07.2017, 12:00 GMT-4
Hi Jeff,
Thanks a lot for your precious advice.
Saurabh
Hi Jeff, Thanks a lot for your precious advice. Saurabh
