Time simulation with limited number of periods
Hi Everyone,
I am trying to simulate a simple system - a piezoelectric disc vibrating in air, with a reflecting surface. My aim is to observe the reflection of the sound waves when they are back to the disc. Problem, I want to send only 2 periods of signal (sine or square signal), but when I use the Functions in Comsol, I find no way to stop it.
Then, my question is probably basic, but I did not find it on the Internet for the while : how to implement a limited time signal in Comsol (that is, the simulation continues to run when the signal ends) ? I use Comsol 5.2 (the message editor does not allow me to put version and recommended topics...).
Thibaut
5 Replies Last Post 06.07.2017, 10:34 GMT-4
Posted: 8 years ago 08.06.2017, 10:57 GMT-4
One option: f(t) = sin(omega*t)*(t<t0)
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Posted: 8 years ago 08.06.2017, 11:10 GMT-4
This was that simple !
And it seems to work, thank you very much Edgar !
Thibaut
This was that simple ! And it seems to work, thank you very much Edgar ! Thibaut
Posted: 8 years ago 12.06.2017, 08:01 GMT-4
I have finally another problem, probably due to piezoelectric materials, but maybe to COMSOL itself.
Using Edgar's Suggestion, the voltage excitation stops after t0, but the disc keeps vibrating. I first thought this was free vibrations due to relaxation, and to the fact I initially did not put any losses. But these vibrations are still here with 100% of mechanical losses, and the same with adding dielectric or coupling losses.
Note that these free vibrations have about the same amplitude than with excitation.
Does anyone know why I obtain such a behavior ? The bottom boundary of the disc is a roller.
Thibaut
Hi, I have finally another problem, probably due to piezoelectric materials, but maybe to COMSOL itself. Using Edgar's Suggestion, the voltage excitation stops after t0, but the disc keeps vibrating. I first thought this was free vibrations due to relaxation, and to the fact I initially did not put any losses. But these vibrations are still here with 100% of mechanical losses, and the same with adding dielectric or coupling losses. Note that these free vibrations have about the same amplitude than with excitation. Does anyone know why I obtain such a behavior ? The bottom boundary of the disc is a roller. Thanks, Thibaut
Posted: 8 years ago 13.06.2017, 06:08 GMT-4
I may have found a solution, using a Gaussian function to smooth the start and stop of the signal.
I have some good results with a sine signal (the free vibrations are about 100 times lower in amplitude than those obtained with excitation), but this does not work with a square signal.
Does anyone know if there is a way to force the system not to move after a certain time ?
Thibaut
I may have found a solution, using a Gaussian function to smooth the start and stop of the signal. I have some good results with a sine signal (the free vibrations are about 100 times lower in amplitude than those obtained with excitation), but this does not work with a square signal. Does anyone know if there is a way to force the system not to move after a certain time ? Thanks, Thibaut
Posted: 7 years ago 06.07.2017, 10:34 GMT-4
It seems that using "Quasi-static", under "Structural Transient Behavior" for "Solid Mechanics" makes it ok.
