7 years ago
18.05.2017, 01:33 GMT-4
Updated:
7 years ago
18.05.2017, 01:47 GMT-4
If you are using 3D Cartesian coordinate, you may get your desired arrow surface plot as follows:
set the x component: x component/magnitude of the vector
set the y component: y component/magnitude of the vector
set the z component: z component/magnitude of the vector
For example,
For velocity field:
x component: u/sqrt(u^2+v^2+w^2)
y component: v/sqrt(u^2+v^2+w^2)
z component: w/sqrt(u^2+v^2+w^2)
For electrical field:
x component: ec.Ex/sqrt(ec.Ex^2+ec.Ey^2+ec.Ez^2)
y component: ec.Ey/sqrt(ec.Ex^2+ec.Ey^2+ec.Ez^2)
z component: ec.Ez/sqrt(ec.Ex^2+ec.Ey^2+ec.Ez^2)
For polar coordinates, the formula is different.
Of course, there should be other ways as well. but this is what I'd do.
Amin,
For example,
For velocity field:
Amin,
NDN
UNIST/Mechanical Engineering
7 years ago
Thanks so much Mohammad Amin Kazemi !
I've done by following your instructions.
Gunnar Andersson
COMSOL Employee
7 years ago
18.05.2017, 02:12 GMT-4
I am newbie in COMSOL,
When I used "Electrostatic Module" to solve Laplace's equation, I need to visualize the Electrical field by arrow, just direction, no need to magnitude
I tried to plot by Arrow Surface but I can not find any option to disable the magnitude of arrow.
The Coloring and Style section in the Arrow plots contains an Arrow length drop-down menu. Set it to Normalized.
[QUOTE]
[/QUOTE]
NDN
7 years ago
18.05.2017, 02:21 GMT-4
Thanks very much Gunnar Andersson
I've also done by your direction.
But I saw that all arrows is same colour. So how can I setup the colour scale for arrows corresponding to their magnitude ? I mean that the arrows will help me to visualize the magnitude via colour scale while the length of them is uniform.
P/S: In box " Colour and Style", I did see any option like " Rainbow"
Thanks in advance
Thanks in advance
Gunnar Andersson
COMSOL Employee
7 years ago
18.05.2017, 02:24 GMT-4
Right-click on the arrow plot and select Color Expression. This adds a subnode where you can define the expression for the arrow color. You can also choose what color table to use.
[QUOTE]
[/QUOTE]
