Error "complex-valued stress function"
HI,
I have already acquired results about the transient temperature distribution of a steel plate processed in the high frequency induction heating. When solid mechanics application was added to analyse the Thermal Elastoplastic deformation of the plate, an error read "complex-valued stress function" was warned.
Need help, Many thanks!
6 Replies Last Post 06.07.2011, 10:32 GMT-4
Posted: 1 decade ago 17.02.2011, 01:18 GMT-5
well I haven't seen that one ;) but if you analyse the sentence you should look at the way you define the stress, could it be that you are entering a complex value when a only real was expected, i.e. you are missing an abs() (+ sign) or a real() or perhaps even an imag() for a variable transfer ?
What are the values of this complex value ? is the complex part negligible ? ...
From thereon you should be able to decide how to continue
Hi well I haven't seen that one ;) but if you analyse the sentence you should look at the way you define the stress, could it be that you are entering a complex value when a only real was expected, i.e. you are missing an abs() (+ sign) or a real() or perhaps even an imag() for a variable transfer ? What are the values of this complex value ? is the complex part negligible ? ... From thereon you should be able to decide how to continue -- Good luck Ivar
Posted: 1 decade ago 30.06.2011, 12:10 GMT-4
I'm having the same problem. I'm using version 3.0a and trying to model the effects of thermal expansion of a wire (elasto-plastic material) inside a ceramic material. I keep getting the following error when its finished:
"Evaluation of post processing expression failed. Complex stress function".
The details on my model follow..
Model:
Axial Symmetry (2D) -> Structural Mechanics Module -> Static Analysis Elasto-Plastic Material model
Constants:
Th=1900+273
Tl=298
Rm=200e-6
Ra=2e-2
ht=1e-2
Em=314.5e9
sy0=414e6
Etm=68.9e9
Scalar Expressions:
currT=Tl+(Th-Tl)*(param*(param<=1)+(2-param)*(param>1))
Draw:
Rectangle 1:
corner at origin; width=Rm, height=ht/2
Rectangle 2:
corner at origin; width=Ra, height=ht/2
Subdomain Settings:
(1 - Inner Material):
elastoplastic material
E=Em
nu=0.380
alpha=5.35e-6
rho=10220
Hardening model: isotropic
yield fn: von Mises
sigma_ys=sy0
E_T_iso=Etm
(2- Main material):
isotropic
E=315e9
nu=.239
alpha=7.8e-6
rho=3690
(1&2):
Load->Include thermal expansion is checked
Tempref=Tl
Temp=currT
Boundary Settings:
(2&5 - 'bottom') Rz=0 (symmetry)
Mesh:
Initialized then refined twice (~8000 elements)
Solve:
Static elastoplastic -> Parametric Nonlinear
param = 0:0.01:2
(ramps temperature from room Temp to 1900°C then back down to room temperature).
Nothing else was changed from the default settings.
I'm having the same problem. I'm using version 3.0a and trying to model the effects of thermal expansion of a wire (elasto-plastic material) inside a ceramic material. I keep getting the following error when its finished: "Evaluation of post processing expression failed. Complex stress function". The details on my model follow.. ==================================== ==================================== Model: Axial Symmetry (2D) -> Structural Mechanics Module -> Static Analysis Elasto-Plastic Material model Constants: Th=1900+273 Tl=298 Rm=200e-6 Ra=2e-2 ht=1e-2 Em=314.5e9 sy0=414e6 Etm=68.9e9 Scalar Expressions: currT=Tl+(Th-Tl)*(param*(param1)) Draw: Rectangle 1: corner at origin; width=Rm, height=ht/2 Rectangle 2: corner at origin; width=Ra, height=ht/2 Subdomain Settings: (1 - Inner Material): elastoplastic material E=Em nu=0.380 alpha=5.35e-6 rho=10220 Hardening model: isotropic yield fn: von Mises sigma_ys=sy0 E_T_iso=Etm (2- Main material): isotropic E=315e9 nu=.239 alpha=7.8e-6 rho=3690 (1&2): Load->Include thermal expansion is checked Tempref=Tl Temp=currT Boundary Settings: (2&5 - 'bottom') Rz=0 (symmetry) Mesh: Initialized then refined twice (~8000 elements) Solve: Static elastoplastic -> Parametric Nonlinear param = 0:0.01:2 (ramps temperature from room Temp to 1900°C then back down to room temperature). Nothing else was changed from the default settings. ===================================== =====================================
Posted: 1 decade ago 30.06.2011, 13:30 GMT-4
It's the combination of elasto-plastic material and thermal expansion that seems to be failing.
The following simpler model receives the same "Complex stress function" error
Draw a 1x1 square
subdomain:
Use the default material, select elasto-plastic, keep default elastoplastic settings (isostatic w/ tangent modulus).
check "include thermal expansion."
Tempref=298
Temp=298+1000*param
no boundary conditions imposed
solver: static elastoplastic -> nonlinear parameter
param=0:0.2:1
It's the combination of elasto-plastic material and thermal expansion that seems to be failing. The following simpler model receives the same "Complex stress function" error ============= Axial Symmetry (2D) -> Structural Mechanics Module -> Static Analysis Elasto-Plastic Material model Draw a 1x1 square subdomain: Use the default material, select elasto-plastic, keep default elastoplastic settings (isostatic w/ tangent modulus). check "include thermal expansion." Tempref=298 Temp=298+1000*param no boundary conditions imposed solver: static elastoplastic -> nonlinear parameter param=0:0.2:1 =================
Posted: 1 decade ago 05.07.2011, 13:59 GMT-4
It's the default von Mises yield function (at least in my case) that is causing the error. Using tresca_axi or s1_axi or real(mises_axi) as the yield function runs through successfully (at least for the simple unrestrained geometry).
mises_axi=sqrt(sx^2+sy^2-sx*sy-sy*sz-sx*sz+3*sxy^2+3*syz^2+3*sxz^2+4*Sys^2*eps)
tresca_axi=max(max(abs(s1-s2),abs(s2-s3)),abs(s1-s3))
It's the default von Mises yield function (at least in my case) that is causing the error. Using tresca_axi or s1_axi or real(mises_axi) as the yield function runs through successfully (at least for the simple unrestrained geometry). mises_axi=sqrt(sx^2+sy^2-sx*sy-sy*sz-sx*sz+3*sxy^2+3*syz^2+3*sxz^2+4*Sys^2*eps) tresca_axi=max(max(abs(s1-s2),abs(s2-s3)),abs(s1-s3))
Posted: 1 decade ago 06.07.2011, 10:23 GMT-4
Your equation for mises_axi is missing an sz^2 term. That’s why it get negative values.
Nagi Elabbasi
Veryst Engineering
Your equation for mises_axi is missing an sz^2 term. That’s why it get negative values. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 06.07.2011, 10:32 GMT-4
Nagi Elabbasi
Veryst Engineering
I apparently forgot it when typing it up above. The mises_axi is a preset variable (so I didn't actually define it within comsol..I was just manually copying it into the forum post from a copy from comsol's variable definition dialog box).
[QUOTE] Your equation for mises_axi is missing an sz^2 term. That’s why it get negative values. Nagi Elabbasi Veryst Engineering [/QUOTE] I apparently forgot it when typing it up above. The mises_axi is a preset variable (so I didn't actually define it within comsol..I was just manually copying it into the forum post from a copy from comsol's variable definition dialog box).
