AC electroosmosis modeling problems
Dear all,
I’ve been trying to rebuild Green’s 2D AC-electroosmosis model on comsol.
I use the weak form mode(w) to solve the laplace equation with pde boundary conditions.
The results of electric field are what i expected but the fluid field velocities are zero everywhere.
(1) The models i use:
Weak Form PDE(w) & Laminar flow(spf)
(2) The equations of the Weak Form PDE(w) model:
 (i) Weak form equation: weak = -test(phix)*phix-test(phiy)*phiy
 (ii) Weak contribution(on electrodes): -(i*ω*C/σ)*test(phi)*(phi-V)
test(phi) is the test function for electric potential “phi”
test(phix) is the test function for tangential electric field “phix”
(3) The boundary condition of the Laminar flow(spf) model:
Slip Velocity (on electrodes)
u = u_slip = -(eΛ/4η)*pd(abs(phi-V)^2, x)
The equations are derived from Green’s article.
Any advice for solving the fluid field problem would be great.
Thanks for your attention.
Reference:
N. G. Green, A. Ramos, A. González, H. Morgan, and A. Castellanos,
Phys. Rev. E 66, 026305 – Published 19 August 2002.
journals.aps.org/pre/abstract/10.1103/PhysRevE.66.026305
1 Reply Last Post 17.08.2017, 01:29 GMT-4
Hello Eric Tseng
NDN UNIST/Mechanical Engineering
Posted: 8 years ago 17.08.2017, 01:29 GMT-4
Hi Eric Tseng
Do you solve your problems?
Best regards
Hi Eric Tseng Do you solve your problems? Best regards
