Eigenfrequencies of a Thin Rectangular Plate
Posted 11.02.2011, 11:54 GMT-5 Geometry, Mesh, Studies & Solvers, Structural Mechanics 10 Replies
I am trying to run an eigenfrequency analysis on a thin rectangular plate. I selected a random material, Steel AISI 4340, and dimensions of 12 in. x 16 in. x 0.04 in. The boundaries along the thin part of the plate are set to fixed. The mode shapes seem to be correct, but I am getting many errors of the following type:
Error: The relative residual is greater than the relative tolerance.
Error: The relative error is greater than the relative tolerance.
I have tried two different mesh types, but I receive the same type of errors with both. The first mesh that I tired was a free tetrahedral mesh. The second type was a swept mesh that swept from surface to surface through the thinnest part of the plate. With the swept mesh, I have set the distribution of elements to various settings from 3 elements up to 15 elements.
I have attempted to check my answer using plate theory, but so far, the answers do not match. I have attached my file. Also, as a note, I do not have the structural mechanics module, and I am using the base COMSOL Multiphysics.
Does anyone know what the problem is?
your shape ratio fits better for a "shell" than rather a solid volume model, or you should have a few elements across the thickness to better model the material behaviour.
I get though less than 10Hz change in the frequency if I use a free extra fine 0.48Melement mesh in 3D mode.
And if I set up a shell model, using a thickness og 0.04[in] I have again less than 1 Hz difference ! from solid (if you add a shell to your solid, do not forget to redefine the material (2), this time to apply to boundaries and not to the domains. A material definition can only be used on either domains or boundaries, but not both in present 4.0 and 4.1)
are you sure the results are that wrong ? I do not have my book on eigenfrequencies of shell with me ;)
By the way, why do you use prescribed velocity =0 on the border and not juste fixed ?
(Im running 4.1)
Your model ====== Fixed ========== Solid 0.48Melements == Shell
Eigenfrequency === Frequency (Hz) == Frequency (Hz) ======= Frequency (Hz)
78.55800 78.55790 76.80660 76.75400
132.4296 132.4296 128.8667 128.7825
189.5057 189.5057 180.7307 180.5927
224.3076 224.3076 214.5552 214.4135
238.2506 238.2506 228.7605 228.5882
323.8044 323.8044 309.8770 309.6438
I appreciate that you took the time to look at the model.
I am not sure that I am getting the right values. They could very well be correct. However, I was worried about it since I was getting an error during the solve (the residual / relative error issue). Also, my frequencies I got from COMSOL did not match what I was getting when I calculated them using plate vibration equations in Matlab. It seems that I need to check my hand calculations again.
I added the prescribed velocity feature, because I didn't know exactly the boundary conditions that "fixed" imposed on the plate. I wanted to make sure that both the displacement and the velocity were equal to 0. Since COMSOL provides the same answer with or without that feature selected, it seems that "fixed' is the only condition that I needed.
Thanks again.
fixed mean no motion hence also no velocity. You shoul upgrade to the latet version, the default convece settings of the solver are better tuned
I have made the tutorial of the Structural Mechanical Module first. Now i tried it with a square plate.
The Model is imported from Solid works. I have also used a quad mesh swept over his thickness
The first few parts of the tutorial works with a huge mesh(750 elements). but now i want to do a 'frequency response' calculation. every time i get the same errors as Dustin Mathias
(Error: The relative residual is greater than the relative tolerance.
Error: The relative error is greater than the relative tolerance.)
it doesn't matter witch parameters i changed nothing happens i tried make a shell of the model but that only more worse/ more errors
I hope somebody can help me
first as general rule, when possible do not (start to) mix solid and shell, except if you know exactly what you are doing ;) there are many subtle issues behind, it's possible but it's delicate work, leave it for later when you mater COMSOl perfectly.
But its absolutely worth making one solid and one separate shell model and compare both. specially for cases as yours
Then my advice: delete all unwanted nodes, extra mesh etc.
Finally, if you need to get the flexing modes you need several mesh elements across the thickness, at least in 3D solid !! this is probably your biggest issue.
the warning (not an error) is an indication that you do not resolve well enough your model.
Finally I would use tri instead of quads for the surface mesh (goes quicker), at least to begin with
reletive Tollerance = 1e-3(standard)
Failed to find a solution for the initial parameter.
The relative error (X) is greater than the relative tolerance
Returned solution has not converged.
reletive Tollerance = 1e-5
Failed to find a solution for all parameters,
even when using the minimum parameter step.
reletive Tollerance = 1e-6
Failed to find a solution.
The relative residual (4.3e-006) is greater than the relative tolerance.
I have the messages only in the Frequency Domain calculation! The staic calculation will work with the standard tollerance
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
I have also the problem that I get the error message for my model:
Error:
Failed to find a solution:
The relative residual (63) is greater than the relative tolerance.
However, this happens only on our "big" computer. When I use our older one or even desktop computer the model is solved as it should.
My question is: How does the computer used influnece comsol parameters, that on one system I get the error message above and on the other system the model runs without problems?
Thank you for your help,
Clemens
Suggested Content
- KNOWLEDGE BASE Error: "Out of memory"
- KNOWLEDGE BASE What to do when a linear stationary model is not solving
- BLOG How Do Chladni Plates Make It Possible to Visualize Sound?
- BLOG How to Provide Structural Stability in Thermal Expansion Simulations
- FORUM Eigenfrequencies for a plate with spring resonators
