Particle Tracing Release Time Bug
I am using the mathematical particle tracing module to release particles with the Release from Grid node. I want to model those particles with a linear elastic particle-particle interaction and have used the appropriate node.
If I release 2 particles with the above setup, the particles behave as expected. This can be seen in the v1.mph file I have included.
Now, I actually want to release more particles into the domain at a later time point in the study. So, I added another time to the Release Times field in the Release from Grid subnode. So I should release 2 particles first, then 2 more later. This is shown in the v2.mph file I have included.
However, when the second release time is added, the behavior of the first 2 particles is changed and incorrect. It is almost as if the 2 non-existant particles which haven't been released yet are affecting the interaction forces between the 2 particles that have already been released.
I'm not sure what to do about this, any help is greatly appreciated!
2 Replies Last Post 29.03.2017, 16:17 GMT-4
Daniel Smith COMSOL Employee
Posted: 8 years ago 29.03.2017, 16:03 GMT-4
Hi Zachary, this is a bug. The particles which have not yet been released act like they are located at the point (0, 0). This will be fixed in V5.3 which is due to be released soon:
www.comsol.com/events/webinar/Introducing-COMSOL-Multiphysics-and-COMSOL-Server-53-28982
In the mean time, there is a workaround, you can change the value of the Spring constant to:
0.1[N/m]*(particlestatus==1)
which means that the force will only act on particles which have been released (and thus have a particlestatus variable set to 1).
Dan
Hi Zachary, this is a bug. The particles which have not yet been released act like they are located at the point (0, 0). This will be fixed in V5.3 which is due to be released soon: https://www.comsol.com/events/webinar/Introducing-COMSOL-Multiphysics-and-COMSOL-Server-53-28982 In the mean time, there is a workaround, you can change the value of the Spring constant to: 0.1[N/m]*(particlestatus==1) which means that the force will only act on particles which have been released (and thus have a particlestatus variable set to 1). Dan
Posted: 8 years ago 29.03.2017, 16:17 GMT-4
Dan,
Thanks so much for the fix, I didn't think to try that.
Dan, Thanks so much for the fix, I didn't think to try that.
