Why conservation of mass is violated in Comsol - Laminar flow?
The model is simple, I use rectangle as my geometry(0.1505m*0.006m) ,and chose laminar flow as my module, then assign inlet boundary condition, which is pressure boundary,10[Pa], outlet condition is 0[Pa], other two boundaries are no slip boundaries. Initial value(velocity and pressure) are specified with 0. After running model, I found outlet flux(1.4441e-6m^2/s) is not equals to inlet flux(1.4491e-6 m^2/s). How does this happen even though I refine the mesh of model? Is this due to resolution of Comsol? Any help will be appreciated. Thanks a lot.
By the way, if I use a more complex geometry, then the outlet flux will more than up to 17% of inlet flux in spite of very finer mesh.
2 Replies Last Post 09.03.2013, 14:30 GMT-5
Posted: 1 decade ago 08.02.2011, 04:13 GMT-5
what would you expect, I see less than 1:200 difference in the values you refer to first, for me FEM is 5-10% in most cases, so I would say it's great.
Ok then you talk about 17% difference, that is in the upper limit, I agree, but are you sure you have correctly tweaked the solver so all parameters are solved with sufficient precision ? Its not only the mesh size
Hi what would you expect, I see less than 1:200 difference in the values you refer to first, for me FEM is 5-10% in most cases, so I would say it's great. Ok then you talk about 17% difference, that is in the upper limit, I agree, but are you sure you have correctly tweaked the solver so all parameters are solved with sufficient precision ? Its not only the mesh size -- Good luck Ivar
Posted: 1 decade ago 09.03.2013, 14:30 GMT-5
Hi Ivar:
What did you mean by "tweak[ing] the solver so all parameters are solved with sufficient precision?"
Thank you.
Hi Ivar: What did you mean by "tweak[ing] the solver so all parameters are solved with sufficient precision?" Thank you.
