8 years ago
07.02.2017, 12:40 GMT-5
If you are using convective heat flux.. and changing ambient temperature. then you can use ambient temperature as a step function or else type this expression in ambient temperature field . if(t<heatingtime, T_hot, T_cold).
8 years ago
08.02.2017, 22:50 GMT-5
Thank you for your quick reply.
In the model, I am applying a heat source which is moving with certain velocity and heating the specimen, when i am defining the time study the heat source is running for the defined time and by that time only heating is happening which i don't want. I want to stop the heat source functioning after certain time to diffuse the heat. for this i have to define heating time and cooling time in same simulation.
Henrik Sönnerlind
COMSOL Employee
8 years ago
09.02.2017, 02:40 GMT-5
Maybe this blog post will give you some ideas:
https://www.comsol.se/blogs/how-to-make-boundary-conditions-conditional-in-your-simulation/
Henrik
8 years ago
09.02.2017, 04:39 GMT-5
Thank you for your response.
Sujit
Sujit
