Can't run Model File for Java in Eclipse
I just started working with COMSOL so I don't know much, but I am trying to automate a process in COMSOL by exporting the COMSOL file into Eclipse as a Model file and running it in Eclipse. The idea is to set up many electrodes and one-by-one test each electrode while disabling all others. All that I'm trying to produce are numerical results exported into a text file, so the GUI is not so important.
The problem is when I run the code I get this error:
java.lang.UnsatisfiedLinkError: com.comsol.nativejni.server.FlRunnable.createRunInfo(Lcom/comsol/nativejni/CPointer;)V
at com.comsol.nativejni.server.FlRunnable.createRunInfo(Native Method)
at com.comsol.nativejni.server.FlRunnable.<init>(Unknown Source)
at com.comsol.nativeutil.runnable.f.<init>(Unknown Source)
at com.comsol.model.method.GeomSequenceMethod$1.<init>(Unknown Source)
at com.comsol.model.method.GeomSequenceMethod.<init>(Unknown Source)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.comsol.model.internal.impl.PrimitiveModelEntityImpl.a(Unknown Source)
at com.comsol.model.internal.impl.PrimitiveModelEntityImpl.bl(Unknown Source)
at com.comsol.model.internal.impl.GeomSequenceImpl.method(Unknown Source)
at com.comsol.model.internal.impl.ModelEntityImpl.h_(Unknown Source)
at com.comsol.model.internal.impl.ModelEntityImpl.tag(Unknown Source)
at com.comsol.model.internal.impl.GeomListImpl.doCreate(Unknown Source)
at com.comsol.model.internal.impl.GeomListImpl.a(Unknown Source)
at com.comsol.model.internal.impl.GeomListImpl$1.a(Unknown Source)
at com.comsol.model.internal.impl.GeomListImpl$1.execute(Unknown Source)
at com.comsol.model.clientserver.ClientManager$1.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Failed to find methods for: com.comsol.model.internal.impl.GeomSequenceImpl
I did some research already and I have already configured the build path in Eclipse to include all of the .jar files in the /plugins directory of COMSOL, so that doesn't seem to be the problem.
The error is actually coming from the beginning of my code in the run() method:
public static Model run() {
Model model = ModelUtil.create("Model");
model.modelPath("C:\\Users\\Marcel\\workspace\\New folder");
model.comments("Untitled\n\n");
model.modelNode().create("comp1");
model.geom().create("geom1", 3); <----the error is here
model.mesh().create("mesh1", "geom1");
I am positive that the error is occurring when creating the geometry because commenting that line gets rid of the error message but causes the program run for an indefinite amount of time.
Can anybody help me solve this problem?
Aaron
3 Replies Last Post 29.05.2017, 13:51 GMT-4
Hello Aaron Yu
Posted: 8 years ago 24.04.2017, 05:52 GMT-4
I am experiencing the same problem. Did you manage to find a solution this problem?
Posted: 8 years ago 25.04.2017, 07:32 GMT-4
This section is from the Programming Reference Manual:
"Select the Environment tab. Click the New button. Use the Name PATH (on Windows), LD_LIBRARY_PATH (on
Linux), or DYLD_LIBRARY_PATH (on Mac) and enter the following text in Value: <comsolinstalldir>/lib/
<platformname> where <comsolinstalladir> is the directory where COMSOL Multiphysics is installed and
<platformname> is one of win64/glnxa64/maci64 depending on your platform. Click Apply."
See if that helps.
Lars Gregersen
Comsol Denmark
Hi This section is from the Programming Reference Manual: "Select the Environment tab. Click the New button. Use the Name PATH (on Windows), LD_LIBRARY_PATH (on Linux), or DYLD_LIBRARY_PATH (on Mac) and enter the following text in Value: /lib/ where is the directory where COMSOL Multiphysics is installed and is one of win64/glnxa64/maci64 depending on your platform. Click Apply." See if that helps. -- Lars Gregersen Comsol Denmark
Posted: 7 years ago 29.05.2017, 13:51 GMT-4
Hey.
But I couldn't find the environment tab in Eclipse 4.6.3.
I am pretty new to JAVA, Eclipse and COMSOL too, as such.
Any help would be greatly appreciated.
Thanks.
Amruth
Hey. But I couldn't find the environment tab in Eclipse 4.6.3. I am pretty new to JAVA, Eclipse and COMSOL too, as such. Any help would be greatly appreciated. Thanks. Amruth
