How to do voltage excitation of a coil in Comsol?
Hello everyone! I am trying to develop Doubly-Fed Induction Generator model in Comsol. To be able to take into account the end-winding effect of the stator and rotor windings, I faced with problem, how to connect field domain with electric circuit model in Comsol. For the coil modeling I am going to use Multi-turn coil node. Because coils should be voltage excited, the best way is to use (External U vs I feature) interface in electric circuit. The description of using U vs I in Comsol manual is very weak.  When I am trying to solve the model, I do not have current in my coil at all, or sometime error message generated.
For the simplicity I uploaded very simple example, of one coil. Could someone please suggest how to connect field and circuit correctly in my case? Thank you very much!
How to do voltage excitation of a coil in Comsol? - ResearchGate. Available from: www.researchgate.net/post/How_to_do_voltage_excitation_of_a_coil_in_Comsol [accessed Dec 20, 2016].
1 Reply Last Post 23.12.2016, 07:22 GMT-5
Dmitry COMSOL Employee
Posted: 8 years ago 23.12.2016, 07:22 GMT-5
Hello, Yury!
It is the best practice to start with our example model form application library:
1) Tranformer model
www.comsol.ru/model/e-core-transformer-14123
2) Inductive heating
www.comsol.ru/model/induction-heating-of-a-steel-billet-330
3) Hysteresis
www.comsol.ru/model/vector-hysteresis-modeling-20671
4) Magnetic field in coils
www.comsol.ru/model/magnetic-field-of-a-helmholtz-coil-15
www.comsol.ru/model/multi-turn-coil-above-an-asymmetric-conductor-plate-13777
Please look through these models. It'll help you to start AC/DC modelling in COMSOL Multiphysics.
Hello, Yury! It is the best practice to start with our example model form application library: 1) Tranformer model https://www.comsol.ru/model/e-core-transformer-14123 2) Inductive heating https://www.comsol.ru/model/induction-heating-of-a-steel-billet-330 3) Hysteresis https://www.comsol.ru/model/vector-hysteresis-modeling-20671 4) Magnetic field in coils https://www.comsol.ru/model/magnetic-field-of-a-helmholtz-coil-15 https://www.comsol.ru/model/multi-turn-coil-above-an-asymmetric-conductor-plate-13777 Please look through these models. It'll help you to start AC/DC modelling in COMSOL Multiphysics.
