pure advection?
Hi there,
Is there a good way to implement an advection equation in COMSOL? something of the form dt(A)+dx(Av)=0 where dt and dx are time and space derivatives.
I've tried using one of the chemical species transport models and setting the diffusivity extremely low (I get an error if I set it explicitly to zero) to solve dt(A)+v*dx(A)=0 and I've entered my own PDE to solve the first equation above. For an initial square wave I get fluctuations near the wave edges that grow with time, just like I would get if I tried to write a basic finite difference approximation of a pure advection equation. Even cutting COMSOL some slack and using a wave with less abrupt changes gives rise to instabilities. Is there a solver setting somewhere that could help? Are there any COMSOL tricks to adding pure advection routines with effectively no diffusion?
Thanks!
Chris
3 Replies Last Post 22.01.2011, 12:32 GMT-5
Posted: 1 decade ago 22.01.2011, 02:31 GMT-5
for leartning how to use COMSOL for PDE's, especially in chemistry, I can only advise to take a look at the book of Zimmermann (see the related "books" on the main COMSOL site)
Hi for leartning how to use COMSOL for PDE's, especially in chemistry, I can only advise to take a look at the book of Zimmermann (see the related "books" on the main COMSOL site) -- Good luck Ivar
Posted: 1 decade ago 22.01.2011, 11:34 GMT-5
Thanks Ivar,
I've looked at the Zimmerman book before and I don't remember it dealing with pure advection. I'm also comfortable using the PDE mode and have set up several of my own equations in past projects. So I don't think it's a matter of how to put the equation into COMSOL's PDE mode.
It's a question of if I put in a PDE with only a time dependent term and a conservative flux term, how does COMSOL solve it? From my tests it seems that it tries to solve it in a similar way to an advection-diffusion problem; it looks just like it would if I tried to solve the conditionally unstable advection equation via finite differences. So what I'm wondering is if this is something I can fix. Yes, I can change the solver, preconditioning, etc., but I think this is a problem with the method in which COMSOL takes my equation and processes it to get it into a solvable form.
Thanks Ivar, I've looked at the Zimmerman book before and I don't remember it dealing with pure advection. I'm also comfortable using the PDE mode and have set up several of my own equations in past projects. So I don't think it's a matter of how to put the equation into COMSOL's PDE mode. It's a question of if I put in a PDE with only a time dependent term and a conservative flux term, how does COMSOL solve it? From my tests it seems that it tries to solve it in a similar way to an advection-diffusion problem; it looks just like it would if I tried to solve the conditionally unstable advection equation via finite differences. So what I'm wondering is if this is something I can fix. Yes, I can change the solver, preconditioning, etc., but I think this is a problem with the method in which COMSOL takes my equation and processes it to get it into a solvable form.
Posted: 1 decade ago 22.01.2011, 12:32 GMT-5
in the new v4 you can really teak nicely the solver sequence, but this is really starting to work correctly from 4.1 I must say. But you need often, in such cases to do some manual tweaking (things tat were far more complicated or required matlab in 3.5)
Hi in the new v4 you can really teak nicely the solver sequence, but this is really starting to work correctly from 4.1 I must say. But you need often, in such cases to do some manual tweaking (things tat were far more complicated or required matlab in 3.5) -- Good luck Ivar
