Immersed boundary condition doable in comsol in solid as well as fluid?
I was not able to find a feature to apply immersed boundary condition for solid in comsol.
Is it possible to do so?
1 Reply Last Post 17.01.2011, 00:41 GMT-5
Posted: 1 decade ago 17.01.2011, 00:41 GMT-5
is it FSI (Fluid Structure Interaction ?) you are looking after, there the link of fluid pressure on bondary load and ALE linking of the displacement is readily set-up. If you do not have FSI toolbox you will have to build thephysics yourself
Hi is it FSI (Fluid Structure Interaction ?) you are looking after, there the link of fluid pressure on bondary load and ALE linking of the displacement is readily set-up. If you do not have FSI toolbox you will have to build thephysics yourself -- Good luck Ivar
