Initial conditions with strange behaviour?
Hello everybody,
I modeled a 3D-model of two bonded wafers. In a first step they cool down from 400°C and deform due to thermal compression. I want to use the resulting stress as an initial condition for the next step which is also structural mechanics. No further load was applied to the structure so when I plot the Mises-Stress for both steps, I should see the same results. But they differ slightly and I find no explanation for this.
I attached my model, so perhaps somebody could take a look at it?
Thanks a lot in advance
Chris
4 Replies Last Post 07.01.2011, 16:00 GMT-5
Posted: 1 decade ago 06.01.2011, 01:18 GMT-5
have you done the layered plate exercise in the model library ? the solution is given therein, you need to add a second stationary solver after the first one and then separate the two physics, one per module. And you should consider one plate at the time. See the example
furthermore, you should as your sysadmin or comsol rep to get hands on the latest 4.1 version (and patch it see comsol web site) as there are many limitation or things making life more difficult than needed in v4.0
Hi have you done the layered plate exercise in the model library ? the solution is given therein, you need to add a second stationary solver after the first one and then separate the two physics, one per module. And you should consider one plate at the time. See the example furthermore, you should as your sysadmin or comsol rep to get hands on the latest 4.1 version (and patch it see comsol web site) as there are many limitation or things making life more difficult than needed in v4.0 -- Good luck Ivar
Posted: 1 decade ago 06.01.2011, 20:17 GMT-5
well, in 2D everything's fine! Separated solvers for both steps were the first thing I tried out... I tried a lot: different boundary-conditions, a finer mesh, but the problem remains.
Don't know what to do now?!
Thought about solving everything in 1 step: cooling down + adding the load. Because it's a stationary solution, that shouldn't be a problem or am I wrong?
Chris
Hi, well, in 2D everything's fine! Separated solvers for both steps were the first thing I tried out... I tried a lot: different boundary-conditions, a finer mesh, but the problem remains. Don't know what to do now?! Thought about solving everything in 1 step: cooling down + adding the load. Because it's a stationary solution, that shouldn't be a problem or am I wrong? Chris
Posted: 1 decade ago 07.01.2011, 02:20 GMT-5
have you tried to do it in 2 steps, 2 sequential stationary solvers, really the layered plate model methodology works also for 3D
Hi have you tried to do it in 2 steps, 2 sequential stationary solvers, really the layered plate model methodology works also for 3D -- Good luck Ivar
Posted: 1 decade ago 07.01.2011, 16:00 GMT-5
Hi Ivar,
what worked now for me: two sequential studies, each with individual solver. The second study assumed the solutions of the first one as initial values. Don't know why ONE sequential solver didn't work?!
However, I've got some new questions regarding boundary conditions. Perhaps it's better to open a new thread...
So far, Chris
Hi Ivar, what worked now for me: two sequential studies, each with individual solver. The second study assumed the solutions of the first one as initial values. Don't know why ONE sequential solver didn't work?! However, I've got some new questions regarding boundary conditions. Perhaps it's better to open a new thread... So far, Chris
