How to plot the imaginary part of the solution
Hi all,
I am solving the heat transfer equation with complex number in it. I think by default COMSOL plotted the real part of the solution, but how to plot the imaginary part? Anyone has this experience? Thanks!
BTW: I am using 3.5a.
Hainan
2 Replies Last Post 05.01.2011, 12:20 MEZ
Posted: 1 decade ago 05.01.2011, 07:42 MEZ
often you must turn on the "complex values" tick box (have forgotten where its hiding in the solver settings I believe) then you need to plot the real() and the imag() parts separately. You have also the "phasor" approach, depending on your variable, see the doc, use the cmplex and phasor as search indexer
Hi often you must turn on the "complex values" tick box (have forgotten where its hiding in the solver settings I believe) then you need to plot the real() and the imag() parts separately. You have also the "phasor" approach, depending on your variable, see the doc, use the cmplex and phasor as search indexer -- Good luck Ivar
Posted: 1 decade ago 05.01.2011, 12:20 MEZ
Hi Ivar,
I got it. Thanks a lot!
Hainan
Hi Ivar, I got it. Thanks a lot! Regards, Hainan
