DOF probe
Hi all,
Can we have a DOF or mesh element count probe? I am running a very large scale mesh studies and I need to have a measure of cost, in some way.
Many thanks,
Danial
Comsol 4.1
Ubuntu 10.04.1
4 Replies Last Post 05.01.2011, 09:25 GMT-5
Posted: 1 decade ago 04.01.2011, 17:43 GMT-5
You can see the number of elements through Mesh>Statistics.
You can see the number of elements through Mesh>Statistics. Jeff
Posted: 1 decade ago 05.01.2011, 01:59 GMT-5
Hi Jeff,
Yes, correct. But I need it as variable to plot since I am running a parametric study.
Danial
Comsol 4.1
Ubuntu 10.04.1
[QUOTE] You can see the number of elements through Mesh>Statistics. Jeff [/QUOTE] Hi Jeff, Yes, correct. But I need it as variable to plot since I am running a parametric study. Danial -- Comsol 4.1 Ubuntu 10.04.1
Daniel Smith COMSOL Employee
Posted: 1 decade ago 05.01.2011, 09:09 GMT-5
Define a Maximum coupling operator with operator name maxop1. Then use the predefined variable "meshelement" to get the total number of mesh elements using:
maxop1(meshelement)
You can plot this v.s. your parameter in postprocessing.
Define a Maximum coupling operator with operator name maxop1. Then use the predefined variable "meshelement" to get the total number of mesh elements using: maxop1(meshelement) You can plot this v.s. your parameter in postprocessing.
Posted: 1 decade ago 05.01.2011, 09:25 GMT-5
maxop1(meshelement)
Exactly what I wanted. Working as advertised.
Thank you!
Comsol 4.1
Ubuntu 10.04.1
[QUOTE] Define a Maximum coupling operator with operator name maxop1. Then use the predefined variable "meshelement" to get the total number of mesh elements using: maxop1(meshelement) You can plot this v.s. your parameter in postprocessing. [/QUOTE] Exactly what I wanted. Working as advertised. Thank you! -- Comsol 4.1 Ubuntu 10.04.1
