create own PDE
Hello everyone!
I try to calculate a vector n which is part of an PDE. This equation consist of a curl and divergence of n.
Is there any possibility to add this PDE in Comsol, although the build-in general and special PDEs do not fit?
The given problem is electrostatic and I am using Comsol Multiphysics 3.5
Thanks a lot.
Best Regards.
Irina Stockem
1 Reply Last Post 03.01.2011, 06:11 GMT-5
Posted: 1 decade ago 03.01.2011, 06:11 GMT-5
normally you can add your equations simply by a) an additional equation in your physics/application mode or b) add a sepcific PDE/ODE physics/application mode (this is valid for 3.5 as well as for v4
there are several examples in the model library, try it out
Hi normally you can add your equations simply by a) an additional equation in your physics/application mode or b) add a sepcific PDE/ODE physics/application mode (this is valid for 3.5 as well as for v4 there are several examples in the model library, try it out -- Good luck Ivar
