No errors but no soultions
Elizabeth Van Heusden
COMSOL beginner, I replicated the permanent magnet steps but for my project and it will compute but then it will not displace any results.??????
Thank you
2 Replies Last Post 06.10.2016, 08:14 GMT-4
Posted: 9 years ago 05.10.2016, 17:40 GMT-4
If there is a solution, you will see the data set listed under Results > Data Sets > Study1/Solution1.
If you have a data set, then you can plot the results.
You may need to create the plots e.g. for 3D model
Results > 3D plot group
and then right click "3D plot group" and insert "Volume" plot
-DW
Hello, If there is a solution, you will see the data set listed under Results > Data Sets > Study1/Solution1. If you have a data set, then you can plot the results. You may need to create the plots e.g. for 3D model Results > 3D plot group and then right click "3D plot group" and insert "Volume" plot -DW
Posted: 9 years ago 06.10.2016, 08:14 GMT-4
DW,
There is a solution set there and I created a few plots but nothing. When I click to look at the results in any field the model disappears.
DW, There is a solution set there and I created a few plots but nothing. When I click to look at the results in any field the model disappears. ?????
