"out" in log file
Below is a log file that I see when I finish running a particular problem. If you look at the log file you notice that the solver says "out" at time steps 0, 0.1, 0.2, 0.3 .....until 1. Then finally the solver says time-stepping completed. What does this mean?
Why is the solver showing "out" at those particular times? If I see the "out" does it mean that the solution converged?
Thanks for the help.
Sirisha
Log file:
Step Time Stepsize Res Jac Sol Order Tfail NLfail
0 0 out 3 3 3 0
1 0.001 0.001 5 4 5 1 0 0
2 0.002 0.001 6 5 6 1 0 0
3 0.004 0.002 7 6 7 2 0 0
4 0.008 0.004 8 7 8 2 0 0
5 0.016 0.008 9 8 9 2 0 0
6 0.032 0.016 10 9 10 2 0 0
7 0.064 0.032 12 10 12 2 0 0
0.1 - out
8 0.128 0.064 14 11 14 2 0 0
9 0.192 0.064 16 12 16 2 0 0
0.2 - out
10 0.256 0.064 18 13 18 2 0 0
0.3 - out
11 0.356 0.1 20 14 20 2 0 0
0.4 - out
12 0.456 0.1 22 15 22 2 0 0
0.5 - out
13 0.556 0.1 24 16 24 2 0 0
0.6 - out
14 0.656 0.1 26 17 26 2 0 0
0.7 - out
15 0.73609 0.080091 28 18 28 2 0 0
0.8 - out
16 0.81618 0.080091 30 19 30 2 0 0
0.9 - out
17 0.91618 0.1 32 20 32 1 0 0
1 - out
18 1.0162 0.1 34 21 34 1 0 0
Time-stepping completed.
Solution time: 288 s.
2 Replies Last Post 29.12.2010, 21:29 GMT-5
Posted: 1 decade ago 29.12.2010, 02:15 GMT-5
"out" means that the solver is storing the results at your whish.
You must know that the solver takes many steps espcially in automatic mode demending on the changes it observes, but by default is stores only the values you are asking for.
You can change the settings so that it saves all values solved for
Hi "out" means that the solver is storing the results at your whish. You must know that the solver takes many steps espcially in automatic mode demending on the changes it observes, but by default is stores only the values you are asking for. You can change the settings so that it saves all values solved for -- Good luck Ivar
Posted: 1 decade ago 29.12.2010, 21:29 GMT-5
Thanks Ivar!
Thanks Ivar!
