Splitting geometry surfaces
Hello all,
I've made a MEMS device in Pro/e and am using the LIVELINK for Pro/e module to use the pro/e geometry in COMSOL.
The issue i'm having is that i need to split my top surface into two parts so that i can apply a voltage and ground BC to the model.
I was wondering if anyone has experiance in splitting surfaces in Pro/e, or any ideas that i could try in COMSOL.
Thanks!
1 Reply Last Post 14.03.2011, 09:21 GMT-4
Hello aiyoung
Posted: 1 decade ago 14.03.2011, 09:21 GMT-4
i don't realy sure whether you already solve the problem or not.
In comsol you can make cutting face on a workplan. and after you finalize the geometry, the parts or surface should be splited.
i hope it helps.
Hi, i don't realy sure whether you already solve the problem or not. In comsol you can make cutting face on a workplan. and after you finalize the geometry, the parts or surface should be splited. i hope it helps.
