How to set a solution-depdendent vaiable?
Posted 02.09.2016, 10:08 GMT-4 Heat Transfer & Phase Change Version 5.1 1 Reply
Hi all,
I want to modeling the curing process of composites, and essentially, it is a transient heat transfer problem. But in my model, some material parameter will change with the temperature, and the temperature is the output result for this problem. So I wonder if there is any way that I can define those variables dependent on temperature. I tried to write these variables as a function of temperature,but it also said the temperature is not defined? I have attached my model and please help me check what's wrong with that.
Thank you very much!
Ge
Ge
1 Reply Last Post 02.09.2016, 10:45 GMT-4
