CMOS photodiode
I am just stuck in simulation of a simple CMOS pin photodiode using silicon meterial. I used two heavy doped n type electrodes with metalic contacts to be grounded( 0 V) and heavy doped p type by applying voltage upto 22V and used thin insulator gate in order to put metalic oxide propery(permitivity 4.5 and thickness of oxide to be 30nm. I used normal mesh element but getting trouble with simulation. every time when i run for simulation i just stopped after incomplete solved degrees and then i got this error.
Failed to find a solution for the initial parameter.
Can anybody please guide me what to do with physics or design or solver to get complete simulation and results. Am i doing wrong by using thin insulator gate element to solve fr CMOS design?
Thanks in advance. Any tips or help would be much appreciated.
Maria
0 Replies Last Post 22.08.2016, 16:30 GMT-4
Hello Maria Jabeen
