14.12.2010, 06:01 GMT-5
I believe those errors are rather linked to missing BC when you couple the physics
By the way isn't it easier (to read) to use a v4.1 "step" function for you shape of "u" ? but probably a "()^41" is still numerical stable
next your conductivities range 30 orders of magnitude !
but the binary number system hardly resolves correctly more than 6-8 taking into account that most physics equations are of second order type, this migh well lead to some errors too.
You might need to do some more tricks here and work in a log scale rather than a linear one
and one more: I do not really understand why you use a separate physics to write just u = my function, what about defining a variable in the main physics ?
But I havnt spent much time on your model so I might well have missed something (or your next quenching modelling step ;)
14.12.2010, 08:42 GMT-5
Thanks for your reply!
I did not understand your meaning that "
You might need to do some more tricks here and work in a log scale rather than a linear one "
In my physics, the transition of resistivity with current is very sharp. Is it the reason that caused the solver error?
You said that it was better work in a log scale. Do you mean that I design the geometry in log scale?
Many thanks!
Zhao
Many thanks!
Zhao
14.12.2010, 09:03 GMT-5
No, not the geometry, its your conductivity change going from 1E-10 to +E+20 that frightens me, the transition is indeed very steep, the numerical solver needs to do operations, take differences etc, long this gradient, if your gradient is too steep the binary representation of the real number, which has its limits, might result in numerical errors and you end up with wrong results.
The log scale idea is to replace sigma by log sigma, an correct the other equations to have a consistent system. But this means rewriting several equations, not sure the solver woud understand etc. So its a long way.
To start with try out with a smaller change from 1E-5 to 1E+5 or something thereabout and then increase until it crashes
