Plot data to Export - Number of data points
Hi all,
How can i determine the number of data 'points' (for example in txt) of an exported plot?
For example, the velocity profile of a fluid flowing inside a cylinder(with D diameter) , may have a curve of n points(in excel) for the D or n+m for the same distance/Diameter.. in other words, the step moving from 0 to D differs and consequently the number of data points(finally i get with txt at excel).
1 Reply Last Post 01.08.2016, 16:02 GMT-4
Posted: 9 years ago 01.08.2016, 16:02 GMT-4
in a data export you can define the points to export, e.g. by defining vectors of coordinates or by setting a regular grid with a defined number of points.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi, in a data export you can define the points to export, e.g. by defining vectors of coordinates or by setting a regular grid with a defined number of points. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
