Calculation of multi-turn Coil Indutance
I have simulated a multi-turn coil (Coil type: Numeric). The coil excitation was set as Current 1A. I used Global Evaluation to get the value of the inductance of the coil. The evaluation expression was mf.intWm*2 (because the 0.5LI^2=W and the I was 1A ). I found that the value that I get was only half of mf.LCoil_1.
I don't know why. Thank you for helping me.
4 Replies Last Post 06.09.2016, 09:39 GMT-4
Hello Tony Adams
Posted: 9 years ago 06.09.2016, 06:47 GMT-4
I'm not entirely sure, just a guestamate.
Was your solution stationary or frequency domain? If in the frequency domain, suppose that the excitation current was 1A peak, hence the rms current is sqrt(2)*1A => i^2 = 0.5*1A, this could explains the 1/2 factor difference.
I'm not entirely sure, just a guestamate. Was your solution stationary or frequency domain? If in the frequency domain, suppose that the excitation current was 1A peak, hence the rms current is sqrt(2)*1A => i^2 = 0.5*1A, this could explains the 1/2 factor difference.
Posted: 9 years ago 06.09.2016, 08:32 GMT-4
Are you using symmetry in your model?
Posted: 9 years ago 06.09.2016, 09:37 GMT-4
wow! It seems so reasonable! Thanks a lot!
[QUOTE] I'm not entirely sure, just a guestamate. Was your solution stationary or frequency domain? If in the frequency domain, suppose that the excitation current was 1A peak, hence the rms current is sqrt(2)*1A => i^2 = 0.5*1A, this could explains the 1/2 factor difference. [/QUOTE] wow! It seems so reasonable! Thanks a lot!
Posted: 9 years ago 06.09.2016, 09:39 GMT-4
No. I simulated in 3D model. Thanks for reply!
[QUOTE] Are you using symmetry in your model? [/QUOTE] No. I simulated in 3D model. Thanks for reply!
