unknown unit error in COMSOL4.0
hi, everyone!
I am a COMSOL4.0 beginner. I simulated a simple 2D-piezoelectric SAW modal. It 's a reatangle in attachment file. Its boundary conditions consisted periodic boundary on two sides and fixed constraint on bottom. When I used m, cm, mm units system, it could work , only many warnings, 'The relative residual is greater than the relative tolerance. Relative residual 8.5e-014 Relative error 1e+002' . However, when i used um unit system, a error occured, 'Unknown unit - Unit: ?m'.
Locate the Geometry Settings section. Find the Units subsection. From the Length unit list, select µm
Thanks for consideration, any help is appreciated.
1 Reply Last Post 01.12.2010, 03:04 GMT-5
Posted: 1 decade ago 01.12.2010, 03:04 GMT-5
there are several weakness in V4.0 concerning default solver settings used, so there are a few fileds to tewak, often the results are still usable even with these warnings. I can only suggest to call your rep and get hands on the latest 4.1 version, the handling of these solver issues are greatly improved
Hi there are several weakness in V4.0 concerning default solver settings used, so there are a few fileds to tewak, often the results are still usable even with these warnings. I can only suggest to call your rep and get hands on the latest 4.1 version, the handling of these solver issues are greatly improved -- Good luck Ivar
