immersed boundary method
Hello everybody ,
i'm really new in Comsol and i'm wondering, if comsol offers the possibility to simulate the flow in an elastic pipe by the immersed boundary method.
Paolo
3 Replies Last Post 27.05.2016, 15:08 GMT-4
Posted: 9 years ago 27.05.2016, 08:44 GMT-4
Hello Paolo,
You can get an introduction to COMSOL's use in Fluid Structure Interaction (FSI) modeling at these links:
www.comsol.com/blogs/kinds-fsi-problems-can-comsol-multiphysics-solve/
www.comsol.com/blogs/fluid-structure-interaction-fsi-using-comsol-multiphysics/
www.comsol.com/model/peristaltic-pump-985
The software does not use the IB method.
Hello Paolo, You can get an introduction to COMSOL's use in Fluid Structure Interaction (FSI) modeling at these links: https://www.comsol.com/blogs/kinds-fsi-problems-can-comsol-multiphysics-solve/ https://www.comsol.com/blogs/fluid-structure-interaction-fsi-using-comsol-multiphysics/ https://www.comsol.com/model/peristaltic-pump-985 The software does not use the IB method. Best regards, Jeff
Posted: 9 years ago 27.05.2016, 09:44 GMT-4
Hi Jeff,
thank you for your answer.
I have two more question.
1.
Is the Fluid Structure Interaction (FSI) modeling tool also able to simulate the extension of a pipe by turbulant flow for example?
2.
I also want to take additionally the effect of some paricles in the fluid.
Is it possible to combine this effect with the first effect?
Paolo
Hi Jeff, thank you for your answer. I have two more question. 1. Is the Fluid Structure Interaction (FSI) modeling tool also able to simulate the extension of a pipe by turbulant flow for example? 2. I also want to take additionally the effect of some paricles in the fluid. Is it possible to combine this effect with the first effect? Best regards, Paolo
Posted: 9 years ago 27.05.2016, 15:08 GMT-4
Hello Paolo,
1/ Yes.
2/ It depends on what you have in mind. I recommend you contact your local COMSOL representative to arrange a more in-depth discussion: www.comsol.com/contact/ .
Hello Paolo, 1/ Yes. 2/ It depends on what you have in mind. I recommend you contact your local COMSOL representative to arrange a more in-depth discussion: www.comsol.com/contact/ . Best regards, Jeff
