Walter Frei
COMSOL Employee
8 years ago
05.05.2016, 08:51 GMT-4
Hello Mark,
You are correct, the CAD Import Module can read SOLIDWORKS® (.sldprt, .sldasm) versions 98-2015, as listed here:
www.comsol.com/products/specifications/cad/
If you do have the LiveLink for SOLIDWORKS® then you can also work with, via the bi-directional CAD link, SOLIDWORKS® (.sldprt, .sldasm) 2015, 2016 files. Keep in mind that, if you do want the bi-directional link, you have to have both softwares running at the same time.
With the CAD Import Module you are also able to import many other CAD file formats, such as Parasolid® (up to V28) or STEP (AP203, AP214), and you should be able to write one of these two file formats out from SOLIDWORKS® 2016, if you do want to work with that version.
Best Regards,
Walter
Hello Mark,
You are correct, the CAD Import Module can read SOLIDWORKS® (.sldprt, .sldasm) versions 98-2015, as listed here: https://www.comsol.com/products/specifications/cad/
Best Regards,
Walter
8 years ago
05.05.2016, 09:17 GMT-4
Thanks for the clarification Walter...
That link you provided had correct information. My initial query came about because of a discrepancy on the following page:
www.comsol.com/livelink-for-solidworks#specs
The text at the top of this page states 2015 and 2016, but the table at the bottom of the page only states 98-2015, (I have highlighted this on the attached pdf). Might just want to update the table to avoid confusion ;-)
Thanks again for the speedy response.
Mark
https://www.comsol.com/livelink-for-solidworks#specs
Mark
Jeff Hiller
COMSOL Employee
8 years ago
06.05.2016, 13:22 GMT-4
Hello Mark,
The text at the top of the page in your pdf talks about the bidirectional interface capability of LiveLink for SolidWorks (which allows the synchronization of a geometry between COMSOL and SolidWorks), whereas the table at the bottom of the page talks about its file import capability. Both statements are accurate, and consistent with Walter's answer above.
As a side note, we anticipate that the CAD Import Module and LiveLink for CAD products will support the SolidWorks version 2016 file format in our next release, 5.2a. Stay tuned, as they say.
Hello Mark,
8 years ago
09.05.2016, 02:10 GMT-4
Hi Jeff,
I see, sorry for the confusion, that makes perfect sense now. I think I will go ahead and get 2016 installed and live with the export of a neutral file type as an intermediate step to get the geometry into Comsol until 5.2a is released.
Thanks for the clarification.
Mark
Hi Jeff,
Mark
8 years ago
09.03.2017, 09:37 GMT-5
Hi all,
I am using Creo to open a Solidworks file (I am not sure what version) and then I export it as a step file.
When I try to import it to Comsol, I receive an error message saying: "No entities to be converted".
Has anyone already faced this problem?
Thanks.
Pavlos.
Hi all,
Thanks.
Pavlos.
8 years ago
09.03.2017, 09:43 GMT-5
Problem solved!
I created a step file, opened it in Creo and created another step file from this one.
Cheers,
Pavlos.
Problem solved!
Cheers,
Pavlos.
