9 years ago
05.05.2016, 08:00 GMT-4
Hi, I am also very interested in EHD simulation. But I cannot understand your model. Are you trying to build the boundary condition equation.
9 years ago
05.05.2016, 09:59 GMT-4
Hi, I just make a EHD using weak form boundary PDE to represent Reynolds Equations. In this model Dirichlet boundary conditions are adopted. A global equation is to guarantee the load balance. Variables are dimensionless. But it does not converge. Have you any experience in this field?
8 years ago
30.11.2016, 02:22 GMT-5
Dear all,
I have built a 1D EHD in COMSOL. But it does not work. There always exists an error. Can anybody give me any suggestion? Please help me! My *.mph file is in the attachment. The error is as follows
The following feature has encountered a problem:
Failed to find a solution.
Singular matrix.
There are 249511 void equations (empty rows in matrix) for the variable comp1.P.
at coordinates: (2.5949,0), (2.5948,0), (2.59482,0), (2.59484,0), (2.59486,0), ...
There are 1 degrees of freedom that do not occur in any equation (empty columns in matrix) for the variable comp1.H0.
at coordinates: (0,0), ...
- Feature: Stationary Solver 1 (sol1/s1)
Thanks a lot!
hi, I also met this problem. Have you figured it out?
[QUOTE]
Dear all,
Singular matrix.
Thanks a lot!
[/QUOTE]
8 years ago
05.12.2016, 13:43 GMT-5
Have you read the papers
Computational Approaches for Modelling Elastohydrodynamic
Lubrication Using Multiphysics Software from Tan, Goodyear, Jimack
www.scs.leeds.ac.uk/pkj/Papers/Journals/TGJTW11.pdf
and
Engineering Software Solution for Thermal Elastohydrodynamic
Lohner, Ziegltrum, Stemplinger, Stahl
www.hindawi.com/journals/at/2016/6507203/
Both are very useful (and open acess) to and provide good examples how to approach the
modelling of EHD.
http://www.scs.leeds.ac.uk/pkj/Papers/Journals/TGJTW11.pdf
and
https://www.hindawi.com/journals/at/2016/6507203/
modelling of EHD.
8 years ago
11.12.2016, 23:23 GMT-5
Yes, I have read both of them, the problem is when I try to use a global equation to couple the problem, COMSOL said "one degree of freedom does not occur", any idea about how to figure this out?
Thanks.
Thanks.
8 years ago
30.12.2016, 04:48 GMT-5
Ok after looking at the attached model there are several mistakes in the implementation.
1. partial derivatives
You use the weak form on boundary and need the derivative dp/dx.
If you use d(P, x) , the result is d(P,x) = 0 . So its obviously wrong.
read COMSOL Reference Manual page 233 regarding
"Differentiation operators: D, PD, and DTANG"
You can either use dtang(P, x) or PTx.
1.2 Use x instead of X
for instance
- dtang(P, X) ( won't work)
- dtang(P,x) -> this work
the dimensionless coordinate X within the formula (Uppercase) is
expressed within COMSOL by a x (Lowercase).
2. Film Thickness H
your code : H = H0 + 0.5*X^2, with X = x/b
better : H = H0 + 0.5*x^2
do not use X ! all your equations are already dimensionless.
Use only x in all expressions.
3. Pressure p
for eta and rho you use p (dimensionally valued). so you have first to define it
with dimensionless pressure P and the maximum hertzian pressure pH
p = P*pH
4. Initial value for H0
You should set the initial value H0 to 1.0 . It does not converge for 0.1
5. Initial value for P
it should be >0 ! so set it to 1
6. Solver settings
at Fully Coupled
set max number of iterations to 100 or 200. 25 is too low.
7. To prescribe P=0 at the boundary points I would suggest
using the Diriclet Boundary Condition only. I think Identity pair + DBC is
too complicated and not necessary.
8. naming convention ( suggestion)
Use Lowercase for dimensionally valued expression
and Uppercase for dimensionless expression
e.g. for density
- rho , dimensionally valued expression
- RHO, dimensionless expression
weak form. You can use one of these two formulations:
1. dtang(test(P),x)*qq
2. test(PTx)*qq
for the variable qq I would define:
RHO*H^3/ETA*dtang(P,x)-A1*RHO*H
or
RHO*H^3/ETA*PTx-A1*RHO*H
I've attached two models
- first is with your naming convention: 1D_EHD_5_4_fixed.mph
- second is with my suggested naming convention: 1D_EHD_5_4_v1.mph
Also the second modell only converged if I use a constant viscosity eta = eta0
Best Regards
for instance
2. Film Thickness H
3. Pressure p
p = P*pH
6. Solver settings
at Fully Coupled
e.g. for density
2. test(PTx)*qq
or
Best Regards
