9 years ago
04.05.2016, 11:03 GMT-4
Hi!
This is the first thing that comes to my mind :
I would try doing it in one study going from 0 to 7 s, and multiply your reaction, let's call it R, by a function, that takes the value 0 from 0 to 3 s, 1 from 3 to 5 and 0 again from 5 to 7 s.
This should be possible by defining a "Rectangle" function in the Definitions node (right-click it) and writing the name of this function*R in your reaction text box.
Julien
Hi!
Julien
9 years ago
06.05.2016, 04:37 GMT-4
Hello, Julien!
Thank you for your advise!
I really agree with your advise.. Here, I have one problem..
I set up an rectangle function shown as attached file which has lower limit of 3 and upper linit of 5.
And I multiplied this rectangle function(rect1) in the reaction text box as : "rect1*R"
However, it seems COMSOL can't recognize the definition of "rect1".
Could you let me know what's wrong here?
Hello, Julien!
9 years ago
06.05.2016, 04:48 GMT-4
Hi woongsun,
I prefer to implement in the function that you specified in the definition > variable >analytic function , and implement the function equation using an If condition statement. lets call the name of the analytic function as an1, which is time dependent.
Now implement the function as an1(t[1/s]) in the place where you want to implement the reaction.
Hope it solves your problem.
-krishnaswamy
Hi woongsun,
-krishnaswamy
9 years ago
06.05.2016, 05:21 GMT-4
Hello, Julien!
Hello, Julien!
9 years ago
06.05.2016, 05:53 GMT-4
Hi, Krishnaswamy!
Thank you for your reply.
I couldn't find analytic function tap as you taught me.. (the definition > variable >analytic function)
Also, could you show me how to use if condition in analytic function??
Hi, Krishnaswamy!
Jeff Hiller
COMSOL Employee
9 years ago
06.05.2016, 07:46 GMT-4
Hello Woongsun,
When you call any function in COMSOL, such as your function "rect1", you need to indicate what argument the function takes, for instance "rect1(t)".
PS: Using boolean expressions based on time for the purpose of turning terms on and off is not typically recommended, due to the lack of differentiability of those terms: the time dependent solver can miss them.
Hello Woongsun,
9 years ago
06.05.2016, 20:38 GMT-4
Hi woongsun,
I have attached the method of implementation in the jpeg file, you can see the highlighted part in yellow,
I am sorry for explaining you in legitimate way,
so, right click the definition under the component > function > analytic.
I have also highlighted the function name as an1, however you can change it to any name that you like and use it further in your implementation as an1(t[1/s]), this t in the bracket denotes the time dependency in the problem. If you plan to change the function name to func then you need to use it as func(t[1/s]).
-krishnaswamy
Hi woongsun,
-krishnaswamy
