Phonons in nanowire
Hi ,
I'm doing simulation about the phonons in nanowires by comsol35 depending on the continuum model,then I I've used the structural mechanics module - solid ,strain stress - Eigenfrequency analysis ,by using the GUI not by script and I got at the end the eigenmodes with their eigenfrequencies, but when I wanted to get the wavevectors that correspond the eigenfrequencies I couldn't,
the process I used as the following:
- design the cylindrical nanowire by the GUI radius=20nm, L=225nm and the material is GaAs ,then the sample is meshed (free mesh) then I solved that for 30 eigenfrequency .
finally from the postprocessing one can get the eigenfrequency easily, but the problem is how to get the wavevector.
I still newbie in comsol so if someone knows how to do that please please help me .
3 Replies Last Post 11.06.2015, 02:12 GMT-4
Hello Hussein Ayedh
Posted: 10 years ago 05.05.2015, 04:57 GMT-4
I have same problem,,
Could you tell me how solved that?
I really thanks about any comments.
I have same problem,, Could you tell me how solved that? I really thanks about any comments.
Posted: 10 years ago 06.05.2015, 12:26 GMT-4
How do you define the wave numbers? Based on longitudinal periodicity?
Posted: 9 years ago 11.06.2015, 02:12 GMT-4
yes, At first, I set lattice constant(= a ), I set periodicity for longitudinal direction.
But I got the bad result(y-axis figure is smaller than expected value.)
yes, At first, I set lattice constant(= a ), I set periodicity for longitudinal direction. But I got the bad result(y-axis figure is smaller than expected value.)
