Please help: applying fixed displacement to a point defined by mesh.
Posted 05.11.2010, 16:26 MEZ 7 Replies
I.e.,
1) Define a square.
2) Generate a mesh for square.
3) Retrieve nodes defined by the mesh.
4) Apply a displacement to a particular node.
5) Solve.
I would really appreciate any help with this. I created this thread because I think my last one was too confusing.
In other software, I am able to select the vertex from the mesh, and apply a displacement. I don't see the option for doing this in COMSOL, since it is restricting me to points manually added when building the geometry.
After collecting the mesh vertices in simulink (using matlab), is it possible to displace them?
I am sorry if I am not wording it right, perhaps someone can point me in the right direction.
Matt
I attached a sample model file.
As an example, I would like to apply a fixed displacement at the mesh vertex (point) close to (.2,.2), without manually adding a geometrical point there.
Can this be done?
Thanks again.
model = ModelUtil.create('Model');
model.modelNode.create('mod1');
geom1 = model.geom.create('geom1', 2);
geom1.feature.create('sq1', 'Square');
geom1.run;
mesh1 = model.mesh.create('mesh1', 'geom1');
mesh1.feature.create('ftri1', 'FreeTri');
mesh1.run('ftri1');
To get the number of mesh vertices, you can use
NumVertex = mesh1.getNumVertex;
To get the coordinates of the mesh vertices as a matrix data where each column
corresponds to a vertex mesh, you can use
Vertex = mesh1.getVertex;
Comsol 4.0a
Ubuntu 10.04.1
That would be perfect, but I am not sure how to add the point load at a point, unless it is a part of the geometry.
i.e., I am trying to use the commands:
model.physics('solid').feature.create(dispname, 'Displacement0', 0);
model.physics('solid').feature(dispname).set('Direction', 1, '1');
model.physics('solid').feature(dispname).set('Direction', 2, '1');
model.physics('solid').feature(dispname).set('U0', 1, .2));
model.physics('solid').feature(dispname).set('U0', 2, .2));
model.physics('solid').feature(dispname).selection.set([point_id]);
However, the last step requires a geometrical point that has already been added (point_id).
Is there a different command that will let me specify the (x,y) coordinates, like you mentioned above, without it being a point that is a part of the geometry? I have all the vertices from the command you have shown. But I am stuck at actually displacing them.
Thanks a lot for your help!
