the same dataset does not run me
Hello
I do my simulation on comsol 3.5 under Windows XP (32bit) with the same dataset the code does not execute me, yet in another computer with xp windows he run normal.
why this problem??
thank you infinitely
1 Reply Last Post 31.10.2010, 10:49 GMT-4
Posted: 1 decade ago 31.10.2010, 10:49 GMT-4
Hi Isabelle
For that one, I cannot help, normally it should run the same, I agree, except if it has to do with a Java installation version that collides, or some RAM issues (but you should be told so).
Here at work we have 3 "identical" PC's, two are ok for our CAD software, the third one crashes, so these things happen for other software too.
Hi Isabelle For that one, I cannot help, normally it should run the same, I agree, except if it has to do with a Java installation version that collides, or some RAM issues (but you should be told so). Here at work we have 3 "identical" PC's, two are ok for our CAD software, the third one crashes, so these things happen for other software too. -- Good luck Ivar
