Learning meshing, any suggestion for beginners?
I have a complicate geometry and needs to be meshed for microfluid flow simulation. However, I've only used the default meshing method before, which does not work for this current case. How could I learn? Is there any good source of material that I can start with?
Thanks!
1 Reply Last Post 03.03.2016, 07:55 MEZ
Bjorn Bretz COMSOL Employee
Posted: 9 years ago 03.03.2016, 07:55 MEZ
Have you seen the meshing tutorial models? These can be found under File > Application Libraries > COMSOL Multiphysics > Meshing Tutorials.
Sincerely,
Bjorn Bretz
Have you seen the meshing tutorial models? These can be found under File > Application Libraries > COMSOL Multiphysics > Meshing Tutorials. Sincerely, Bjorn Bretz
