21.10.2010, 07:08 GMT-4
by default COMSOL implements several derivatives (spatial and temporal) have you checked the equations view to see if also in raw PDE mode, these are generated by default ? I cannot remember just now which are present) In the 3.5 doc there was a list of all variables for each "application mode", I havent seen it updated in V4 yet
Magnus Ringh
COMSOL Employee
21.10.2010, 10:28 GMT-4
This is a bit tricky but possible.
In version 4, add a Constraint node and specify that R is the constraint R = 0 is
1-ut
ut is COMSOL syntax for du/dt. This constrains du/dt to 1 at the boundary where the Constraint node is active. You also need to make the following modifications in the Settings window for the Constraint node:
- Select "Unidirectional" from the "Constraint type" list because the bidirectional constraint attempts to apply the test function on the time derivative of u, which is not supported.
- Select the "Use weak constraints" check box because pointwise constraints for time derivatives are not supported.
Magnus Ringh, COMSOL
1-ut
21.10.2010, 14:52 GMT-4
Thank you for your time. I will try these solutions. If I can't find anything I will ask again with more details.
05.04.2012, 06:25 GMT-4
1-ut
Hi, I use comsol3.5a. I met the same erro during a transient elasto-plastic analysis. In my model, the identity pairs is also used. I selected the weak constraints as you recommended,but it didn't work. Looking forward to your help
[QUOTE]
1-ut
[/QUOTE]
05.04.2012, 08:03 GMT-4
Hi, I am trying something similar where I am trying to specify a periodic boundary condition between two boundaries and equate it to the average of the strain over the volume multiplied with the difference in position vector. I tried it in verson 4.2 in stationary mode with a thermal strain but COMSOL is unable to solve it. Could you help?
14.04.2012, 14:06 GMT-4
Hi all,
Now I am trying to model a rotating machinery in AC/DC Module. It is exactly an axial flux permanent magnet synchronous generator.
I`ve finished the geometry and model of the generator. Yes, It`s like a disc, so it will be more efficient than the radial one.
These are the explanation of my model:
- Permanent magnet poles are pleced in the back yoke of rotor.
- Stator, which consist of some winding/coil, are placed between the two rotor. I`m using coreless stator one.
- There is air gap between rotor and stator.
I have adjusted the subdomain physics settings by choosing the material and the H-B equation, but I have no idea, what I have to do next.. So users, please suggest me what I have to adjust next.
- How to adjust the boundary settings?
- What function and equation that I`ve to give for the model.. In what part?
- and how to visualize the outcoming voltage of every phase of the generator??
Thank you
Halim, Zahari
Hi all,
Thank you
Halim, Zahari
