9 years ago
25.02.2016, 04:49 GMT-5
the up and down values can be different on material interfaces. There, the stress tensor
has a jump discontinuity.
I don't have the RF module, but in ACDC physicses there is a force computation feature.
Have you tried this? That should do all the integrations as you need them.
Regards
Jens
Regards
Jens
9 years ago
25.02.2016, 05:04 GMT-5
Hi Jens.
Many thanks for your answer.
I can calculate the force by integrating the dnTx over a particle surrounding surface.
Fx = int_surf(emw.dnTx)
Fy = int_surf(emw.dnTy)
Fz = int_surf(emw.dnTz)
and the results are satisfatory compared with Mie theory.
However, I don't know how to implement the torque that is given by the expression:
\int_{S}{\mathbf{n}\cdot(T\times\mathbf{r})}
also written the the paper cited previously.
Many thanks
Hi Jens.
Many thanks
9 years ago
29.02.2016, 03:17 GMT-5
Hi!
Finally I found the solution.
Maxwell stress Tensor must be implemented and all operations become much easier.
Hi!
9 years ago
18.03.2016, 03:03 GMT-4
Hi!
Dear Nuno,
Is your formula of the Torque using Maxwell stress Tensor like the below ?
Torque_x=emw.dnTy*z-emw.dnTz*y
Torque_y=emw.dnTz*x-emw.dnTx*z
Torque_z=emw.dnTx*y-emw.dnTy*x
(it was supposed that the rotational central point is at the origin points with coordinate (0,0,0) )
Looking forward to your reply, Thx.
[QUOTE]
Hi!
[/QUOTE]
Dear Nuno,
9 years ago
02.06.2016, 22:49 GMT-4
Hi, Yao,
I'm calculating the same model.Since that T=-intop(T crossproduct r). Seems you missed a minus sign?
Hi, Yao,
9 years ago
02.06.2016, 23:03 GMT-4
Hi!
I've the same questions. It puzzle me a lot that what's the difference between ewfd.dnTx and ewfd.unTx.
And all of you use F=intop(ewfd.dnTx), why not unTx instead?Is there a direction in it?
I've tried both, it turns out that the sign of the results are reversed(the sphere is not the boundary of particle and medium, I generated a sphere over it in the surrounding medium so the tensor is continue).So I don't understand clearly.
Waiting for reply~
Thank!
Hi!
Waiting for reply~
Thank!
9 years ago
14.06.2016, 16:10 GMT-4
Dear Nunoé
I am also to caculate the Torque through Maxwell Stress Tensor of the NPs particles.
I ask for your help to clear how to solve this problem.
I have caculate the Maxwell Stress Tensor.
Thanks a lot!
Have a good day!
Yuhua
yuhua.yang.1@ulaval.ca
Dear Nunoé
Thanks a lot!
Have a good day!
Yuhua
9 years ago
24.09.2016, 10:31 GMT-4
Hi!
Waiting for reply~
Thank!
Dear Huatian Hu,
you can refer to the previous discussion (
cn.comsol.com/community/forums/general/thread/39198). The choice depend on your model geometry. A "trial and error" step is strongly suggested for any problem that is relate to MST.
[QUOTE]
Hi!
Waiting for reply~
Thank!
[/QUOTE]
Dear Huatian Hu,
you can refer to the previous discussion (http://cn.comsol.com/community/forums/general/thread/39198). The choice depend on your model geometry. A "trial and error" step is strongly suggested for any problem that is relate to MST.
9 years ago
24.09.2016, 10:38 GMT-4
Dear Nunoé
Thanks a lot!
Have a good day!
Yuhua
Dear Yuhua,
I think the off-diagonal elements of the stress tensor, not just the diagonal elements ,i.e, emw.dnTx,y,z, is the must to calculate the torque. Maybe we should define the every elements of MST through the variables in COMSOL, then use them in the integration of the shear force. I am not sure. Hope have a further discussion with you.
[QUOTE]
Dear Nunoé
Thanks a lot!
Have a good day!
Yuhua
[/QUOTE]
Dear Yuhua,
