Crashing by meshing + transparency
when i mesh my object and i get warnings , i want to look for the problem and want to see my object . some of the mistakes are invisible for me so i had to use the function button transparency.
if i do that the program crash everytime .
i try it for other object.
it's the same.
2 Replies Last Post 11.02.2016, 03:40 GMT-5
Posted: 9 years ago 10.02.2016, 19:42 GMT-5
This is very likely a graphics card problem. You could try updating your graphics card driver, or -especially if it happens in 3D only- switch the rendering (under File > Preferences) to "software" instead of the default OpenGL.
This is very likely a graphics card problem. You could try updating your graphics card driver, or -especially if it happens in 3D only- switch the rendering (under File > Preferences) to "software" instead of the default OpenGL. Best, Jeff
Posted: 9 years ago 11.02.2016, 03:40 GMT-5
Thank you for the answer.
i will check this
Thank you for the answer. i will check this
