14.10.2010, 18:18 GMT-4
ave you tried to click several tims, normally you cycle through the objects "hit" by the projection view. Sometimes transparent or wireframe is showing it up better
14.10.2010, 18:30 GMT-4
Thanks Ivar, I tried multiple times hit, it worked.
Irfan
Irfan
Ruud Borger
COMSOL Employee
15.10.2010, 05:09 GMT-4
Hello Irfan,
In addition to what you tried, it can help to hide objects that are in front of it. The hide-buttons are located above the graphics window.
What's more, once you have selected those "buried" surfaces, it can be helpful to save the selection. To do this, go to "Definitions" and then "Add selection". Alternatively, when you have selected them under a boundary condition, there is a small button that will automatically save the current selection. Be sure to give it an appropriate name though!
Good luck,
Ruud Borger,
Comsol
Hello Irfan,
Good luck,
Ruud Borger,
Comsol
15.10.2010, 16:06 GMT-4
It is really wonderful and what I am looking for.
Irfan
Irfan
16.10.2010, 05:02 GMT-4
do not forget that you can have several views (under definitions and under Results (postprocessing) with different "hide" levels (only for views under Definitions)
9 years ago
05.01.2016, 00:00 GMT-5
Hi, I am trying to make one side of a triangle transparent but it is not working. Is there any simple way of doing it in Comsol 5.1 for ray optics module?
Jeff Hiller
COMSOL Employee
9 years ago
06.01.2016, 09:54 GMT-5
This is now a really old thread, but I want to point out that the default way to select geometric entities like boundaries changed a while back. The following link should be useful when it comes to the more recent versions:
www.comsol.com/support/knowledgebase/1168/
http://www.comsol.com/support/knowledgebase/1168/
