Three phase flow problem
Gnana Ganesh Ekambaram
I'm getting the following errors when I try simulating droplet separation process. I've attached my file for reference.
Attempt to evaluate real square root of negative number.
Function: sqrt
Expression: nojac(1/sqrt((54*emetric2)+((4*comp1.spf.rho)*emetric(comp1.u,comp1.v))))
Failed to evaluate variable.
Variable: comp1.tfpf1.tau mCross
Variable: comp1.tfpf1.vhNS lin, Defined as: (sqrt(max((((comp1.tfpf1.xi m*comp1.tfpf1.res u)^2)+((comp1.tfpf1.xi m*comp1.tfpf1.res v)^2))*comp1.tfpf1.tau mCross,0)*comp1.tfpf1.B0YigijtauNorm2)*0.5)/(comp1.tfpf1.B0YigijtauNorm2+eps)
Expression: nojac((1.4142135623730951^(1-shapeorder(comp1.u)))*max(comp1.tfpf1.vhNS lin-comp1.tfpf1.vhNS quad,0))
Variable: comp1.spf.vhNS
Failed to evaluate temporary symbolic derivative variable.
Variable: comp1.spf.crosswindnsVDN${test24}
Expression: d((comp1.spf.crosswindns)*(dvol),{test24})
Failed to evaluate Jacobian of expression.
Expression: (comp1.spf.crosswindns)*(dvol)
1 Reply Last Post 23.02.2017, 19:02 GMT-5
Hello Gnana Ganesh Ekambaram
Posted: 8 years ago 23.02.2017, 19:02 GMT-5
i'm also facing same problem. Can u help me?
